Hi everyone,
I’m facing a problem connecting my PC to EAF. The connection will be disrupted after seconds of its begin then it’s can not be found anymore.
i checked the cables and switched them with EWF, tried to connect the EAF with PC with separate USB cable, installed the drives again and did all update but still no change: the EAF didn’t Funktion and can’t be connected to PC.
Interesting is: the EAF works fine on other PC, but if connect the ASI 1600 it stops to work und can’t be found anymore .
Did anyone faced such a problem?
thanks and clear skies,
