I have just started using an ASI183MM pro for photometry and have been using ASIImg for image capture. The filenames have the sensor temperature included which means the file list is sorted in temperature order instead of time order which causes problems with later processing. Is there any way of excluding sensor temperature from the filename, or putting it after the time ?
