Hi Sam,
I'm aware of the isochronous streaming problem cause by usb3 (and that Intel simply choose to ignore the problem...).
That being said, my capture pc is only equiped with usb3 ports with no possibilities of adding a pci card (Dell XPS One 27). I was able to get the camera working under Firecapture 2.2 and the asi drivers. That setup was working at full speed even with the use of a 15' usb extention cable.
With 2.3b and the sdk it does not. From what i understand, after some research on the web, it seems that it might be possible to disable the drivers for them usb3 ports from within the bios or simply from the device manager in Windows depending on one's pc. By doing so, all usb3 ports would actually behave as usb2 ports.
I would like to avoid this solution as when i capture with the camera, the data is saved directly on a usb3 portable drive...
My question is, do you have any suggestion for a workaround ?
Thanks in advance,
Sincerely,
Alain
