Hi, the problem I have, is actually connecting everything together. I have a few more items:
CPC1100
T-Adapter - SCT (Canon EOS) works fine.
ZWO Atmospheric Dispersion Corrector
ZWO Filter Drawer - M42, can connect one side, not the other
UV IR Cut Filter 1.25 inch, have fitted this ok
Celestron f6.3 Reducer Corrector, have fitted this ok after removing the visual back, the diagonal has also been removed
ASI462MC Imager
I guess the issue I have is, do I have to reduce what I use in order to keep it to 55mm, and what spacers do I need to connect each of these components together? Some just connect, some don't. Finally, what order do these items need to go in? I am guessing the F6.3 goes first, connected to where the visual back was, I can connect the camera ok to this, but the other items are problematic.
Not sure why they do not just provide this information when you buy the stuff, or at least tell you what other spacers etc you need to get it working correctly.
