Don't forget the RA-Only dither settings too, if you plan on using dither (highly recommended, to reduce effects from warm and hot pixels).
Since you don't have declination compensation, make sure you have very good Polar Alignment (better than a mount that has declination motor). Otherwise, your declination pointing will slowly creep towards the north or to the south. You will not just get field rotation, but also the shifting of the frame. The target will move away from the center.
Mounts with no declination motors are really only satisfactory for short focal lengths (think camera lenses), short exposure times (well less than 300 seconds) and how long you are accumulating the subframes.
