Dear all,
i'm going to try to take some deep sky image with 120mm with a cold box self made but in firecapture i've only .ser to select for 16 bit. i understand that .ser files are a sequence of .fit, is correct? there is a way to take pic in .fit format or "explode" .ser in .fit?
Thanx so much
.ser is a video format like avi.
you can also select to save as .fit or tif format in FC2.3
Cool thanx.
But if i decide to take a .ser file i've automatically a 16 bit file or i have to select somwhere an option 16 bit in fc 2.3?
Inviato dal mio U8800pro con Tapatalk 2
you need to enable 16bit output, so it can save the video in 16bit.
.ser can save in 8 bit too
and where may i enable this?
there is a 16bit option check box in the left up side of FC2.3.
but 16bit is only available when use ASI120MM
