Perfectly normal.
I have a EFW 5x2" that have these holes, 8 on one side and 4 on the other.
One set of holes let you bolt the EFW directly flush onto a camera after you remove the camera's tilt plate. The side with 4 holes lets you attach an OAG to the filter wheel, likewise flushed, all without using any threaded spacers. The tilt plate that you removed from the camera is then attached to the empty end of the OAG; or you can buy a tilt plate with different hole size.
For your 7x36mm, take a look at the documentation here:
https://astronomy-imaging-camera.com/product/new-zwo-efw-7x36mm
Scroll down about half way and you can see a set of four images with the holes indicated with blue circles.
It is odd that you have only 6 holes on the camera side, though. You might have some older model?
