I was wondering if anyone has experience using a 12 volt USB C Power Delivery Trigger Cable with a Krisdonia Portable 185Wh/50000mAh Power Bank to supply the ASIAIR Pro? I measured the no load output of the voltage at the end of the cable and got 12.10 volts. To me that seems on the low end considering the recommended 12 - 15 volt for the ASIAIR Pro. The trigger cable states it supplies 12 volts and 5 amps. Maybe I should go to a 15 volt 5A trigger cable instead?
Not sure how to measure the volts when the ASIAIR Pro is loading with all ports being used. Any thoughts, experience, suggestions are greatly appreciated!
