Hello! I have a telescope newton 10" f/4, a 294mm pro, a filter wheel starlight xpress & filter 31,1 (baader planetarium) and this configuration vignetting. A filter wheel zwo does solve the problem or am I forced to change filters?
Thank you
I have checked if you use ZWO filter wheel 31mm for 294 camera, your telescope should be >f/3.7, so it should be Ok since yours is f/4.
Thank you. I will arrange to buy the zwo wheel if so. Thanks so much.
