Hi, I would like to flash my very old ASI120MM with the compatible firmware for use with my linux box. But when i start FWUpdate program a segmentation fault (core dumped) appear.
Ubuntu 20.04.02 Lts kernel 5.4.0-77
Thx Kris
Hi, Can you attach some screenshot about this fault?
Hi,
i tried with --help with the same issue.
You may need to do that as root. Perhaps the /dev device for the camera is not writable for user christian?
thank you for your reply. I tested as root and i have the same issue. I look the lib used by the program and nothing special (like a lib compile by myself).
I always used this program before without issue...
Thx
