Equipment --
Star Adventurer Pro 2i
Canon t3i Ha modified
Zenithstar 61ii
Asi 120mm mini
Asi 30F4 guide scope
Ok so for the first month or so that I had the Asiair Pro it worked phenomenally. I could set everything up and go to sleep, let it run the whole night no issues. I do that at least seven or eight times. There have been multiple updates to the AAP since then and I can't figure out if this is a software issue I'm having or it's hardware?
There have been numerous threads and numerous people who have mentioned issues with guiding, especially since the multi star update but it's hard to say for certain if the issue was update related since there are so many hardware combinations out there.
So the other night I was out for around three hours and tried all sorts of different settings and combinations to remedy the issue and I'm hoping I managed to get enough data to be useful. I'm still quite new to all this so I don't fully understand the nuances of what's contained in the guide log so any help is appreciated.
Here is the issue, I will set up calibration (single star or multi star, it doesn't seem to matter) and everything will go fine. I am easily getting 2 minute subs with round stars and could go longer. Unguided it appeared 60 seconds was max with the Zenthstar 61ii before stars went oblong so it is obvious the guiding works. I will get six to seven subs in and the RA guiding goes wild. I've seen it shoot up 50"! The star is completely lost.
My polar alignment through the AAP was showing 2" (!) and throughout the night when checked through plate solving my DEC moved less than 2', I slightly adjusted it once if I remember correctly. Everytime the guiding went wild it was only the RA I needed to adjust so my polar alignment is good I believe.
As the night went on I tried fiddling with different settings in the app, and it showed some improvement with RA numbers. When it was working it tightened up the RA, at times to sub 1". That's good! Unfortunately, like clockwork, six or seven two minute exposures later and boom it would go wild again.
I am so close to just being ready to rock here, my setup and takedown routine is chef kiss. I can use plate solve to find my object in minutes despite no goto. Everything is mint, except I have zero confidence in the guiding now because of these issues. I have to sit and babysit the thing, and it slaughters any exposure time I have. I managed to gather about an hour and a half worth of data in almost three hours because of this nonsense.
I hope I've providing enough information here to help with trying to figure this out, this forum hasn't let me down yet when it has come to my incessant questions since I started last year and I'm hoping I can get some answers on what exactly is happening here! Are there others who are having this issues? I appreciate any help, thanks in advance.
Here is the log...
