Hi,
I've recent acquired a CEM40 and have run some stability tests on the connection between this mount and a MK1 ASIAIR.
I have found that the connection persistently fails after 10 minutes or so.
I'm using the iOptron cable between mount and ASIAIR and have connected to the correct mount port. Mount is powered via mains, ASI connected to a fully charged Tracer battery.
No other components connected at this stage.
Any thoughts on why this happens, greatly appreciated.
Thanks, Klaus
