freed
This is because the humidity is high inside the sensor and they are frozen on the sensor glass when the temperature drops quickly,
we recommend you slowly cooling the camera to solve the problem:
Before letting it cool down to target cooling temp, please keep it at 5℃ for 5-10 minutes, then cool it down to target temp and if this continues to appear, it will basically disappear in 5-6 minutes.
