prevalain When I get the eyepiece out and mount my ASI 462MC camera on it, I can no longer get in focus using SharpCap
That simply means that your camera is not parfocal with your eyepiece. You need to refocus the telescope after replacing the eyepiece with a camera.
I see that you are posting to the ASIAIR forum -- in which case, you can try using the Video mode of the ASIAIR to achieve focus.
Remember that focusing with a camera requires much more precision than focusing visually, since your eye muscle is part of the "focusing train" and the brain adapts to small misfocus. The camera has no such adaptation and the sensor needs to be perfectly placed at the focal point of the optics.
Focusing takes a little patience, but if you have an electronic focuser on your telescope, you can at least do the focusing indoors with ASIAIR, away from the heat and brightness of the Sun.
