Hello,
I have a recent problem that just occurred and I can't figure out what happened.
Equipment:
IOptron GEM45 (powered through Pegasus)
ASIAir Pro (powered through Pegasus)
ASI 294 pro camera (powered through Pegasus)
Pegasus (powered through AC home electricity)
I have had my ASIAir Pro and mount connected for the past 6 months, I did add the Pegasus about a month ago.
Anyway I was trying to use "the Plan" function for the first time, had 2 sessions loaded, I was13 images into the first session and my mount slewed to start and lost connection with my ASIAir app.
Since then I have switched cables and even switched ASIAir Pro (from my other scope).  My ASIAir Pro app initially shows connected to my mount, but when I try to PA or GOTO nothing happens and when I go back to my mount icon on the app it shows the mount is not connected.   What is odd, is that when it  first connects, it will let me move the mount with my phone/tablet app, but as soon as I try to GOTO or PA it disconnects.
The only change I have made to my setup recently was adding a Pegasus box that powers everything and everything seems to work, my mount turns on and will slew with the hand controller, I just can't control with my mount with the ASIAir app.  And it was working with the Pegasus box for a couple of weeks.   I am perplexed for sure.  I am going to see if there are any new firmware updates for my mount, I believe I have the recent updates for my ASIAir app.
Thanks, any help will be greatly appreciated.  Jim....
