Hi, the ASI294 could also be a good alternative for me as a lunar and planetary camera, so I am also interested in the answer.
What I can tell you is that the 183MM pro that I currently use is a very good option, unless you are mainly interested in IR imaging. Good response in the visible, 2.4um pixels, fast (was, before the current driver issue), with very large FOV for the moon and for centering planets.
Extra FOV allows for software like SharpCap to maintain the planet centered during ling periods even if alignment is not perfect.
I leave you with a recent planetary mosaic and a lunarscape (Tych
o) obtained with the 183MM.
Also check this link for a 294 evaluation:
http://www.astrosurf.com/buil/asi294mm/
António
