@tech@zwo#48724 ok, I get where the disconnect is.
The proposed intervalometer function is intended to be used by a lot of "non-supported" cameras (mostly DSLRs and MILCs) so users can utilize the dithering capabilities of ASIAir Pro as long as their camera supports remotes/intervalometers. This is not for ZWO cameras. Unfortunately whatever "intervalometer" functionality some DSLRs/MILCs have is insufficient for deep sky astrophotography and a lot of beginner astrophotographers start with the equipment that they have - usually DLSRs or MILCs and camera lenses.
As mentioned, an intervalometer function is not expected to handle/cover image storage and other advanced functionality that are astrophotography-specific. All we ask is a means to specify
- a delay before the first picture is taken
- how long each exposure is
- how many exposures to take
and that the ASIAir Pro triggers the camera's shutter via the 2.5mm port such that it's integrated with the dithering functionality e.g.
- wait for the specified delay
- open the shutter via the 2.5mm port for the specified exposure length
- close shutter via 2.5mm port
- dither along the RA/DEC axes
- wait until the rig is stabilized based on the guidescope
- repeat the process for the specified number of exposures
That's it. This integration with the ASIAir Pro's dithering function will set you apart from other intervalometer manufacturers. This will also save you guys the effort of integrating different brands and models like how you are doing now for say, the Nikon Z series. Most intervalometers work across different brands/models since there seems to be a standard protocol, it's just a matter of having different brand/model-specific cables.
Now, I get the concern that introducing this functionality might eat into ZWO camera sales. I believe it will have an opposite effect. An intervalometer functionality will further lower the barrier of entry for people new to the hobby (those who only have DSLRs or MILCs) and will allow them to have an early taste of the good stuff (dithered images, all-in-one automation, etc) so to speak. It's a fact DSLRs and MILCs can never beat dedicated cameras in terms of performance or functionality in astrophotography, and the sooner people max out their existing cameras, the sooner they'll buy the dedicated cameras and related gear. Which ZWO has, and is already known to work well with their existing ASIAir Pro ie it's easier to get buy-in if a user knows the upgrades will work with his/her existing gear.
If I can help clarify this further just drop a line. Thanks for reading and support in this one.
