Hi, ZWO staff
Sorry, I could not reproduced it again. Driver seems just normal, now.
I can set 'highest D range' as 'gain 0' in default. and it did not switch back to gain 72.
I always use SGP 64bit, it had been only supplied as beta till 23th July. It had some bugs or troubles there, I and they confirmed. Last week end, I find SGP 64 stable version had started, and I replaced. I don't think SGP would harm the ASCOM drivers in normal, though it could happen. I confirmed SGP can't control Pegasus switch driver in properly as now. so, I deleted that driver. The trouble, Pegasus switch will stop the SGP staring when not connected, disappeared.
That behavior of gain 72 appeared in SGP 64 beta version. It may happen when back it again. In Last month, when I select 'highest D', they show 72 in the slider, and moved to Zero manually, it showed 'manual' as mode. It's all mystery!
Anyway, It seem solved. Sorry for bothering.
Regards
Hiromu
Japan
