What is worng.... When i use the ASI Vonets Wifi extender it crashes everytime...
It works great during PA or when i am traning whit my scope. But as soon the PA is over or i want to go onm autorun the Wifi extender loses the signal and the software freeze... It is everytime....
Can you confirm this is a wifi extender issue, have you tried without the extender if there is same crash issue?
@tech@zwo#48718 it works great without the extender when i am using the ASIAIR as hotspot. Only problem with that is the poor range.
but everytime i Connect the vonets and after og during the P.A, it freeze and crash
Here is the wifi extender manual about more advanced settings: https://astronomy-imaging-camera.com/manuals/ZWO_WiFi_Extender_Quick_Guide_EN_V1.0.pdf
@tech@zwo#48752 how in the world should this help me!????
brandmandsam Like switch between 2.4G and 5G, and other settings(such as channel change) to give it a try first.
Hi, the booklet shows connection to a pc but the ASIAIR pro is WiFi so no need for a pc. Why does the instruction manual not show connection to the aap?
denababy Because this manual is from Vonets(manufacturer), this wifi extender is for AAP only.
Thanks for that but is there anywhere a pictorial description of how and what to do to ensure there is a connection between the Vonets and the aap?
denababy Have you tried the basic instruction on the product page first? https://astronomy-imaging-camera.com/product/zwo-wifi-extender
