@tech@zwo#48883 @tech@zwo#48883
Hello,
asiair pro is fed by LEDMO adapter 12V-10A .
- on the asiair power outlets I only connect the EAF power plug
- on the asiair USB outlets there are the EAF usb plug, the gemini with serial-usb adapter and the asi071mc pro usb outlet
- asi071 cooling is fed by a separate power adapter and works fine
- gemini (level4 associated with g11) is also fed by a separate power adapter.
Everything works fine until I get the message « EAF lost connection » and then « reconnect EAF _manually «
Do you think it is a power feeding problem or a usb problem ?
Thanks for your help
Pierre
