Hi, I posted it it went somewhere but I don’t know where. My question is; instead of using the provided cable that connects from the handcontroller to the aap, what are the benefits of using an EQMOD cable therefore taking the hc out of use.
What is your mount? Only Skywatcher mount can use EQMOD cable.
Hi, my mount is a Skywatcher eq3-2
Hi, Not sure about EQ3-2, EQ3-pro should be ok. If EQMOD does not work, you have to use HC(SynScan) to connect.
