wvreeven.. Are you using ASCOM? If so, it appears that ASCOM is changing the defaults from 95/52 to 50/50, or perhaps APT is also doing a low level reset of the WB_B and WB_R to 50/50.. What has come to light is that the default is 95/52.. Why is not clear as but at those levels clipping will occur and there is the "potential" for affecting other colors. If no other software, e.g. ASCOM, INDI, within Sharpcap (which has WB sliders) talks to the camera, it will be 95/52 and you will get Blue. In theory, you can subtract the Blue with PI and others, but the clipping will have already occurred..
