As @Kring mentioned, display the Guide graph in the Guide window.
Before ASIAIR v1.7 Beta, the aggressiveness (and Declination mode) settings are above the guide graph, with ASIAIR 1.7, they have moved to the far right of the graph (at least up to Build 7). Betas are fluid, and things may change. The control to select whether you want to see the correction pulses has also moved; it was on the far right before, and it is now on the far left.
