Thanks for your reply.
Definitely the suggestion to correct the angle of inclination of the sensor does not work, because I do not find that the stars are blurred in a part of a photograph. The problem is that the image, for example of Jupiter, cannot focus directly, after seeing it in the center of the field of view with the Finder, or the ASI 290 guide camera or the eyepiece mounted on the TAK 150 telescope. the image of <Jupiter when placing the ASI6200MC Camera. I have to move with the control of the mount, the axes and the entire telescope until I can see Jupiter and when looking at the deviation in the Finder's viewer, the error is about one degree.
What lights can you give me?
