crispy5573 Incidentally I just checked the temperature of a low energy light bulb ....54C
That sounds pretty much as expected too.
An "60 watt incandescent equivalent" LED light bulb from Philips consumes about 8.5 Watts, almost all of which is dissipated in the form of heat. (Some newer bulbs are a bit more efficient.)
The Raspberry Pi 4 consumes about 3.5 Watts at idle and 7.5 Watts at "full" load; again, all of which is dissipated in the form of heat.
So, unless the Raspberry Pi 4 enclosure has a larger surface area to dissipate the heat (or a fan to help move the warm air), I expect it to feel as hot as a 3.5W to 7.5W light bulb.
This is why I added a heat sink to my ASIAIR. The fins of the heat sink have a lot of total surface area. If I wanted even cooler, I would add a fan to remove the warm air from between the fins.
All that heat has to go somewhere, and if it is not radiated into the air (increasing the temperature of the air), it would increase the temperature of the device itself. If you want the device to be cooler, use a large heatsink (like I did) or use a fan to help help move the heat into the air.
