I need to set the focus for my guide camera, an ASI74 attached to the ZWO mini guide scope. I could not sort out how to see images from the guide scope in preview mode. not in the script to initiate guiding. Should I be using something else like Sharpcap to do this task?
eaf
Connect the ASI174 as the camera in your Main Camera menu.
w7ay Can this be done in software, or does one need to swap USB cables?
Also, can those cables be hot-swapped?
JeffMorgan
Main Camera menu.
The main menu at the top of the Main Camera window.
