ben_eisenstein Is there a way to enter a value for the video exposure in ASIAIR Pro for the ASI462MC camera.
In Video window, under the large round button, you will find the FOV/ROI menu.  And under that menu is a large "less than" symbol.  Tap on that "less than" symbol.
Then tap on EXP (for exposure).
It will show a vertical scroller in µs or ms range, depending on the selection that you mentioned.
Scroll the vertical scroller up and down to change exposure values.
The large "less than" symbol becomes a large "greater than" symbol to collapse that interface (their UI programmer was too lazy to draw filled triangles, I suppose).
This is not the worst UI in ASIAIR; you will eventually encounter much worse, and inconsistent, UI in the rest of the ASIAIR app.
At least they have finally replaced the equally meaningless Ellipsis icon by a real icon with an "i" embedded in a filled circle in the ASIAIR beta.
