Hi All,
Well, I've got the Solution thanks to PHD2 Group. Firstly let me say that the USB HUB is working fine and has no problems.
Further comms with PHD2 members, the Autoguiding software needs to built the first Profile with the Guiding camera plugged only, its mean the Imaging camera MUST be unplugged. Do you have an old Profile, I suggest you to dlete zll them in order to get a Clear Profle. Once is done, and you connect the Imaging camera , you can choice the Autoguiding camera Clicking USB Icon on the Bottom Left of the PHD2 at the Fork Icon, or two arrows Icon, pls see the attached Image, the Icon is inside a Orange Square) and click on the desired Camera. With this option PHD2 will use the Autoguiding Camera despite both are connected and both to an USB HUB. pls, remember that as the new Cameras demmand more power, you'll need a Self powered USB HUB, its mean with its own power supply (15$ cost only) so a lot of PCs and Laptops USB Ports are not available to provide with all the Power that we need. Since now all is working Fine.
Now its time to solve guiding issues that doesn't allow me to take exposures over 300s.......... We allways will have a little problem to solve 😁.
@tech@zwo#49522 @Denali @jays_ct @mcerono .... I hope this will help you with your connection problems.
Best Regards,
Frank
