I have used a ASI120MM as a guide camera with PHD2 running on my windows laptop since 2015 and have not had connection issues.
Recently, I purchased a ASI2600MC-Pro as my new imaging camera, and a ASIAIR-Pro to control both imaging and guide cameras. Both cameras and the ASIAIR Pro are ZWO products. The ASIAIR Pro appears to work correctly and can control the ASI2600MC-Pro, as the imaging camera, But I am surprised that the ASIAIR Pro doesn't connect to the ASI120MM, or even offer it in the list of cameras to connect to. In the connection box, the only camera listed is the ASI2600MC. I have tried four different USB cables and I have tried connecting the ASI120MM directly to the ASIAIR and also to the hub on the back of the ASI2600MC. So far, nothing works.
Last night, I set up the guide camera, connected to my laptop via USB and confirmed, using PHD2, that the camera is functional and in fact, I got good guiding during this test. Then I switched and connected the camera to the ASIAIR Pro, turned on the Pro, connected my tablet with ASIAIR app, and once again, it never offered a connection to the ASI120MM.
I'm stumped as to why the ASIAIR sees and connects to the ASI2600MC-Pro but can't do the same for the ASI120MM. Until this gets solved, I can't guide my images. What advice do you have?
Thanks,
JohnLF
