That does not look like Moiré. Moiré tends to have a much finer repeated pattern whose pattern changes as you magnify the image.
What you have looks suspiciously like ice on the sensor.
If it is an icing problem, are you cooling the ASI071? If so, do not take it directly to the target temperature.
Take it to just above freezing first and let it sit there for 5 or 10 minutes, before taking it down below freezing. Even better, take it down in multiple steps, +10ºC, +5ºC, 0ºC, -5ºC, -10ºC for example, resting for a couple of minutes between the steps.
It may also be time to swap (or recharge) the desiccant tablets in the camera.
