Home position difference. I have a sct11 edgeHD with cgxl and AAP. I do not understand why the Home position using the hand control is different than the home position when using AAP. I have turned off the AAP while in hand control home position but that did not make much difference. I am sure it is some kind of sequencing thing. Thanks for the input.
I don't have your specific mount but I think I've ran into this before. See if your mount has different positions set for "Home" and "Park" and if so, try making them the same and see if that fixes the issue.
