@tech@zwo#49659 sorry, i don‘t think this feature request relates to my original post.
I second this request to be able to add a break after any part of an autorun sequence. Let’s say i have a scope without EFW but with a filter tray where you have to change filters manually and i program AAP to take 30 Ha frames. I would like to flip a switch in the autorun settings for this filter/frame combination to break autorun after that filter/frame combination is finished, until i manually resume autorun and after i changed the filter to O3. For the O3 filter, i would have programmed the sequence before starting the whole session (at the time i programmed the Ha filter sequence).
HTH. Best, Olli
