Hi, I have a camera compatible 120 MM, and because of eratique behavior in 16bits mode (lot of frames dropped whatever the configuration) i tried to upgrade the firmware USB 2.0, hopping it would solve. In 8 bits with 120 MM driver, everythings ok.
The uploading worked fine, but then, meanwhile the camera is still recognized by windows when plug-in, it does not respond anymore and even the firmware uploader software it does not detect the camera.
Is there a way to reload the firmware?
Best regards.
