Would it be possible to add at e.g. "Plan" a (Re-)GOTO?
Reason: If you are outside / in the field and you can't setup your rig 100% to north (or tripod moves/drifting over the hours a little bit at the muddy field, windy conditions, "bumping at the rig by mistake" etc.), a "RE-GOTO after X Frames" would be nice, to keep the target always centered.
If having the ability to do that, the quantity of the waste images, or even the whole session would be fewer.
And having finally more usable size of the sensor/image, because of better overlapping with always nearly perfect object-centered images at the later stacking / post-processing.
