I have a GPS receiver for my Celestron AVX mount, and manually input the latitude and longitude from the mount into the ASIAIR app on my PC. With 8.11/1.6 app/firmware on my ASIAIR Pro, this worked fine. Now, when the app syncs to the mount, it pulls 262° East instead of 97° West. This causes some issues with what it thinks it can aim at, refusing to point West due to where it thinks the horizon is.
I power on the mount first, and don't connect the USB cable until after it determines when and where it is from GPS and complete a one star alignment. The mount was polar aligned first using the PA function and manually moving the mount. Disconnecting and resyncing did not fix it, and I was able to replicate the issue two separate days at two different locations. The erroneous longitude read from the mount was the same at both locations.
