awhitson If I manually move the RA to 60 degrees there is no response from the ASIAir and I can't PA my mount.
If you want to manually move the mount RA axis by the 60 degree angle, you have to first tell ASIAIR that there is no mount connected in the Telescope Setup window.
Then go to Polar Alignment window and follow the instructions there (it will tell you when to move the 60 degrees).
After polar alignment is complete,  Home your mount, reboot the mount's electronics, star align the mount, and then connect ASIAIR Telescope back to the mount.
