Hi, I Have adquired a ASI2600MCPRO and testing with Sharpcap the response is nonlinear 34% or 33% or similar. Any idea that if that is an common error or something similar?
Kind regards.
Hello, Can you attach some screenshot of Sharpcap to show us the problem? Thanks!
I make several test with sharpcap in differente moments. And the worst result has been 34% of non-linearity.
Waiting for your answer. Thank you.
Txus
Anot her test another day in the recent past.
Thank you
Hi, Have you tried another software about the result? I mean I can't tell this is the camera parameters or just a wrong data from sharpcap.
Please indicate us the correct system to test and evaluate it.
Hello I tried to search for the correct linearity test of an ASI2600 PRO. My camera presents a bad behaviour since the begining. Each time is degrading with time. As you can see in the image. Now the linearity descends to 25% !!! I'm contacting you during the guarantee period of the camera. I hope you can give me a good support to avoid the problems. Now also I can see oil leakage in the sensor and this is a fault that I cannot assume. Please could you help me and inform about the correst test for validate the behaviour of the camera?
Thank you in advance.
Txus, Spain
