Hi,
I have an ASI120MC, for some reason last night the whitebalance setting did not want to move, it was all the way down. I tried restarting SharpCap and even tried on another laptop.
What could be causing this?
Regards,
Dinesh
Is it auto WB?
WB setting only works in RGB24 output
Hi Sam,
I checked again on both laptops and a desktop now, I have the latest beta of sharpcap on one and the 1.5.x version on the others. Not on auto WB and set to RGB24 but still wont't budge. Everything else seems to work perfectly.
the white balance in the UI of sharpcap won't move.
you can only set auto.
you need to adjust it in "video input filter" page
Ok thanks Sam :)
