Hello,
my problem is:
when my ASI2600MC Pro cooling system obtains an activity of 100% it turns off immediately while the fan still continues to operate, cooling power displays 100% and temperature rises. It is attached to asiair pro with latest updates via USB3 and 12V supply. Cooling below 35 ℃ ambient temperature will be achieved, therefore I assume the cooling system itself is accurate.
As several users of the ASI2600MC Pro complaining about the same issue I suspect a common problem.
At troubleshooting I connected the camera to a separate 12V Power adapter and voila, the
flaw vanished. It appears that when pluged into the ASI Air, the ASI2600MC Pro cooling power switches off at 97-99%. ASIAir itself was provided with 12V/6A Power.
@ZWO my proposal for a solution:
ASIAIR pro:
- add settings option to limit cooling power of ASI2600MC Pro to 95%
- add settings option to turn off internal WIFI during runtime (at boot time WIFI should always be turned on)
 > external Router in bridge mode via RJ45 jack can be used instead
I'm looking forward to a solution, because loss of cooling will spoil an entire  astro session.
Maybe someone has already an idea.
Many thanks for any response.
Astrolix
THX to ZWO for providing beneficial equipment particular for field astronomy and supporting Linux.
