I can not get my iOptron CEM 26 mount to flip via the Asiair Pro. It flips fine if I program the mount to do it, but not with Asiair. By the way I am doing this with only the mount. No scope, etc. The following statement was something to try, but I need details of how to carry it out. Thanks
Test the actual Meridian time of the equatorial mount: When the AIR prompts to start Meridian Flip, but the equatorial mount does not turn, you can try to use the hand controller to send the goto command to see when the equatorial mount flips. This time difference is calculated by the AIR and the mount Meridian . The time difference will always exist. You can set this time difference in Meridian Flip.
