Hello,
I have been needing to delete about 1/4 of my images lately as they will have streaks or double stars. My tracking will look good, between 0.5 and 0.8, but about every 3rd or 4th image will be bad. I tried really tightening down my guidescope thinking maybe it was causing some drift. I do wonder if I am pushing the limits of my mount. I am using an IOptron GEM45 which has a 45 lbs limit, but I have read you should stay at 50% of that limit which I am probably exceeding. I have ES 127mm ED that weighs 18lbs, but I sure by the time you add up camera, filter wheel, EAF, extenders, guidescope, ASIAir pro, etc I have probably added another 10lbs. I have attached my tracking logs from last night and pic of the double stars.
