astronebulee what are the shitter speeds I woukd need to type into the exposure length
I assume you mean shutter speeds?
Recall that at Full Moon, the center of the Moon receives the same amount of light from the Sun as the noonday Earth does. So the old "1/ASA, f/16 rule," that we used before exposure meters became common in cameras, holds. Does not work during a lunar eclipse of course.
The only difference between full Moon and noonday Earth is the Albedo of the Moon vs Earth (which depends on whether you are on a beach vs a football field, anyway). They are within a factor of about 2 of one another (Moon's albedo is lower), so just give the Full Moon one extra f-stop compared to noonday Earth.
When it is Full moon, just start with the settings you would use when you take pictures down your street at Noon when it is sunny, and increase the exposure by one f-stop.
The best is to just look at the histogram and max ADU of a preview image and tune so there are no pixel saturates. If you use up the maximum of the histogram without it saturating, you can recover everything during post processing.
