WalterT Although, I have also wondered why there aren’t any consumer level mounts with motorized Alt/AZ adjustment controls.
Walter, check out the Avalon M-zero obs model (M-zero is their low end mount). Motorized polar alignment has been around for a while now.
On top of that, with a motorized field rotator like the Optec Pyxis, you won't even need to have good polar alignment. Guiding simply need to correct for three axes, x and y (like in 2D PHD2), and theta (angle).
IMHO, a permanent pier with a weather proof cover over the mount is a better solution.
