Hi,
I have an issue with your EAF V2 used with Focusmax V4.
Sometimes, the position reached is different than the one ordered by the software.
For example, if i am at pos 5500, i ask for 5750 and it stops at 5824, and it can happen either for IN or OUT moves.
I have tested with NINA and i don't see any issue, then with the driver itself, no issues also.
I am doing moves with 250 steps starting from 5500, once OUT, twice IN, twice OUT etc.... and with Focusmax sometimes it falls on a wrong position.
I could not reproduce that with other tools like NINA, Finepix, or the driver itself.
CCDWARE support doesn't see any explanation from them, it seems that they use the ASCOM driver and not the native drive. So they ask me to raise the question to you.
Other point : if i want to uninstall the ASCOM driver i am unable to find any unistall function anywhere. How is it possible to uninstall the ASCOM driver on Windows ?
