Explain the process you are going through to get an object. If you start on the "Preview" mode, then select an object from the Catalog and execute a "GoTo", once the ASIAIR goes to the object and plate solves it to center it, the ASIAIR should come back to the Preview screen with the object centered on the screen. To get more images of the object you need to press the big white button to get another image or you can set of "Preview" mode to continuously take images based on the current exposure setting. This can be set up in "Main Camera" > "Advanced" settings section > "Continuous preview" button.
JohnD
