keramos Other than the above will I ever need to use the hand controller prior to using the ASIAIR Pro?
No, except for what you mentioned, and also the RA/declination offset calibrations, you do not need the hand controller.  I never use the Hubo-i when the RST-135 is attached to an ASIAIR.  Even when I use the RST-135 for daytime solar work in conjunction with the Hinode guider, with the ASIAIR capturing images and the Hinode autoguiding the mount.
See here if you want to calibrate the RA and declination offsets (the precise home position instead of the uncalibrated home sensor positions), with which you do need the hand controller (to save some time, I had used a two axis inclinometer when I calibrated my offset, instead of his flipping a single axis inclinometer back and forth):
https://www.youtube.com/watch?v=7IC1j8i-1H4
This is important to do if you want the auto meridian flip time to be in sync.  You only need to calibrate it once, and after that simply depend on the a level or an inclinometer to establish level to use auto meridian flip (in the worst case, every 1 degree of East-West level error corresponds to 4 minutes of time delay for a flip -- up to five Auto Meridian Flip retries on the ASIAIR).
It is much better to have the hand controller absent since its GPS time would not interfere with ASIAIR's UTC.  The GPS of the RST-135 (unlike the RST-150h) is in the hand controller and not in the mount body; and that is also why you also get best GPS acquisition with the button side of the hand controller facing the ground.  As fas as DST goes, just let ASIAIR in iOS push the UTC over to the ASIAIR.  Neither the ASIAIR nor the RST-135 understands Daylight Saving Time, so they are perfectly "compatible."   Syncing location and time has not failed me since ASIAIR v1.3 (when the RST-135 protocol became fully functional in ASIAIR) on iOS as long as you give full Location Services permission to the ASIAIR app.
