Still learning the ZWO 294MC Pro and ASIStudio. I noticed that the auto stacking feature has a window to select Darks, Bias and Flats to be used in the auto stacking. However, do you use a file that is a master of each or just one file of each? Oh, the auto stacking only lets you use one file of the Darks, Bias and Flats, thus the question on using a master of those in the auto stacking of the Lights. When I stack pictures in other programs, I generally stack several of each; Dark, Bias and Flat but sometimes too many of one makes the picture go black. I tried a master stack of say 5-Darks in the auto stack with the Lights and the auto stacking ended up black. Doing tonight some auto stacking using only one of each and seems to be doing okay. I do save each Light picture just to try and get better results in other programs. Oh, the program does not have a Flat Dark tab and I would like to make one.
