Hello,
i have an idea (i dont now if its new..)
The DSLR Output only works, if i use the Slider into the Software. If i work with the Output, the other Output via USB Cable dont works anymore.
Can you make an Firmwareupdate for the DSLP port on the AsiAirPro, so that it works EVERY Time to ?
Becaus if you do that, i can work with a main camera (like my Asi 2600mc-pro or DSLR on my Skope AND with the DSLR output or a second camear like DSLR with fotolens.
Is it now problem, the AsiAir dont have a Fokus Option and others for this option, because with fotolens with big Filed of viwe it is nor so hard to fokus etc.
Regards
Oliver Schneider
www.balkonsternwarte.de
