Would be great if the EAF would remember the focus set points by filter and allow me to use them as 1) default positions unless other conditions change (time, temperature, etc), 2) starting points for fine focusing to reduce the time it takes with the V-curve routine between filter wheel changes. In both cases, I am trying to maximize the accuracy of my focus while minimizing the time focusing takes away from light capture of objects.
Thank you, Peter
