Hi,
I have an ASIair Pro (maybe 8.46 - 1.7). I tried it two days ago and worked absolutely well. But yesterday I had a problem.
I aligned the mount to the NCP, the steps went well but after the push "Finish" displayed "calculating" and did happen nothing. Just freezed. I can stopped it and try it again but the error was same the next times.
I have a SW EQ-6R Pro and use its USB port.
Do you have an idea?
Thanks!
